How to increase "Number of loading steps" in Adsorption Locator?
Dear all,
Why is not an "Number of loading steps" option available in Adsorption Locator module? This leads the simulation to stop in high loading numbers. I solved the problem with applying "LoadingMoves" setting in script. However it would be more convenient to have such an option in Adsorption Locator Calculation dialog, like that in Sorption module.
Regards
Farsin
Answers 2
CM
CM 2022-06-03
I am not sure I am getting your point.
Anyway, what about enlarging the steps per cycle value (StepsPerCycle in scripting)?
Or why do you think that this is not sufficient?
FK
FK 2022-06-03
Thank you.
With Number of cycles=3 and Steps per cycle=15000, the job was unsuccessful with following error message:
Status: Error
Error description: Unable to load the requested number of molecules in 100000 steps.
I don't know how the value of 100000 is editable from the dialog.
The "LoadingMoves" setting in scripting works well, and only required loading steps are used. However, with increasing the value of "StepsPerCycle" the total simulation time considerably grows because all steps must be used.
