How to determine HOMO LUMO using Dmol3 ?
We have Materials Studio 4.2. We need to determine HOMO LUMO of naphthalimide derivatives. Kindly help in this regard.
Answers 2
CM
CM 2011-04-14
Dear Jean,
I do not remember any more how it was for Materials Studio 4.2 but in Materials Studio 5.5 *.input files which are generated contain this line:
Print                         eigval_last_it
Now after each SCF run the eigenvalues, symmetries, and occupations of each orbital is printed as well as which orbital is the HOMO and which is the LUMO.
This should work in Materials Studio 4.2 as well.
Kind regards
Carsten Menke
Energy of Highest Occupied Molecular Orbital  -0.23717Ha    -6.454eV
  HOMO is orbital number     5
  LUMO is orbital number     6
    state                         eigenvalue        occupation
                              (au)          (ev)
    1   +   1    a1.1    -18.758867      -510.455     2.000
    2   +   2    a1.1     -0.862886       -23.480     2.000
    3   +   1    b1.1     -0.434808       -11.832     2.000
    4   +   3    a1.1     -0.311275        -8.470     2.000
    5   +   1    b2.1     -0.237166        -6.454     2.000
    6   +   4    a1.1     -0.010114        -0.275     0.000
    7   +   2    b1.1      0.055218         1.503     0.000
    8   +   5    a1.1      0.551478        15.006     0.000
   10   +   2    b2.1      0.600277        16.334     0.000
   14   +   1    a2.1      1.072140        29.174     0.000
  Orbital occupation is:
    3   a1( 2)
    0   a2( 2)
    1   b1( 2)
    1   b2( 2)
  Total number electrons:              10.0
HP
HP 2015-05-08
Dear Jean.
The carsten reply the checking orbital in outmol.
I want to introduce determination and visulaization of homo and lumo with analysis process in MS visualizer. I also don't know about 4.2 version but i'm sure that you can see the homo and lumo orbital in your ms visualizer.
Before determine or visualize homo and lumo orbital, you should calculate the target molecules involving orbital calculation. I mean you need to check orbitals in properties tab. If you will do this process, you can see the enegy level of homo and lumo as well as
the distribution of electrons in homo and lumo
Best wishes
Sunwoo Kang
comment imagecomment imagecomment imagecomment image
