Hello Everyone,
I need to choose specific atoms in Material studio. Therefore, I choose pattern command and find specific atoms and then created a set for atoms which I wanted to select. Now I want to hide or delete all atoms belong to created set. How can I do this in material studio without any script?
Thanks,
Ankit
Hi.
I think...
Select "Edit | Edit Sets" to open "Edit Sets" diarog.
And select set's name and "Select".
Next delete key.
Hi, Taishi Kuroki. It does not work. It would delete set's name not atoms belong to a set.
When I select a set name and click "Select", are the atoms in the set selected and turned yellow?
Append...
Add that the delete key is on the keyboard, not the button in the "Edit Sets" dialog.
I click on set ( COOH, created). It shows all highlighted COOH atoms with yellow cage. Then I right click and click on delete. But It is deleting only highlighted yellow cage not atoms.
From what I know it is not really possible to remove atoms from a set.
I would do the following:
1. Select the atoms of the set.
2. Deselect the atom you want t remove from the set.
3 Make a new set
The only idea I have at the moment.
