How to change the location of job directry created by gateway?
Hi all,
(I'm posting again since I posted in a wrong topic.)
I am runing Mareterial Syudio on WIndows.
When I run a project on server, the gater way creates a job folder in
C:\\ProgramData\\BIOVIA\\Materials Studio\\17.2\\Gateway-x64\\root_default\\dsd
(I guess this is the deafault).
How can I change this location?
I would like to use a Ramdisk for speeding-up.
Thanks in advance
Iwa
Answers 4
TI
TI 2018-06-19
How about using "junction" feature of Windows?
TI
TI 2018-06-19
Sorry, by mistake I've submit only the first line of my reply.
CM
CM 2018-06-21
From my experience "softlinks" do not work. It did not come up for a while but from what I remember there is a restriction to the location of the jobs folder due to security policies.
Rather than having a drive letter you can mount a disk usng the Windows Disk Managment tool. If you mount the complete SSD under C:\ProgramData\BIOVIA\Materials Studio\18.1\Gateway-x64\root_default\dsd\jobs it works for me using another disk.
CM
CM 2018-07-16
This procedure which worked for me (I “only” had to reinstall Materials Studio once because I destroyed my local Materials Studio gateway installation) for Materials Studio 2018 on Windows 7 Professional 64bit:
1. Start a cmd.exe with Run as Administrator.
2. In the cmd.exe cd to C:\Program Files (x86)\BIOVIA\Materials Studio 18.1 x64 Server\etc\Gateway
run these commands:
3. gwstopservice.bat
 double check via the Services window that the service is really stop (use F5 to refresh the view)
4. gwuninstallservice.bat
5.gwdeconfigureall.bat
6. config\configure servers -jobspath c:/GW
7. gwstartservice.bat
c:/GW is really a forward slash. GW has to be replaced by the path to the directory which will hold the gateway installation afterwards (not just the jobs directory). I suggest not to use spaces or non-ASCII characters other an a-z, 0-9, and - or _.
Before that procedure is applied please make sure that:
  • No Job is running any more.
  • All jobs are downloaded.
  • All jobs are deleted from the gateway.
  • Be prepared to reinstall Materials Studio if something goes wrong.
I leave it up to you if you want to take the risk and want to try that. Mounting a complete disk sounds safer for me.
