How to calculate the free energy of solvation (Dmol3) ?
Dear all, I'm working on the graphene oxide system that interacts with a cation , I calculated the energy in vacuum for the system:
Cycle Total Energy Energy change Max Gradient Max Displacement
opt== 31 -4420.4093457 -0.0000183 0.001148 0.004785
and also applied COSMO calculation were I obtained:
Energy components:
Sum of atomic energies = -4390.3641518Ha
Kinetic = -48.1626202Ha
Electrostatic = -0.0722417Ha
Exchange-correlation = 11.1177754Ha
Spin polarization = 7.1823871Ha
DFT-D correction = -0.2053994Ha
Total DFT-D energy = -4420.5042507Ha
Total Energy Binding E Time Iter
Ef -4420.504251Ha -30.1400989Ha 14.4m 10
Df binding energy extrapolated to T=0K -30.1150071 Ha -819.47139 eV
Diel. energy -0.120121 -0.120121
DMol3/COSMO Results
cosmo energy [Hartree atomic units] [eV] [kcal/mol]
Total energy = -4420.504251
Total energy + OC corr. = -4420.504251
Dielectric (solvation) energy = -0.120121 -3.269 -75.38
Diel. energy + OC corr. = -0.120121 -3.269 -75.38
Surface area of cavity [au] = 3176.430
Total Volume of cavity [au] = 7858.367
Surface area of cavity [A**2] = 889.491016
Total Volume of cavity [A**3] = 1164.489851
screening charge
cosmo = -0.00001
corrected total = -0.00001
so my question is: HOW CAN I GET the free energy of solvation (Dmol3) or even the solubility from these data ?
I fond this on the internet :
Determination of nonelectrostatic contributions to the free energy of solvation
but I still cannot figure it out how to do this ?
Thank you in advance for your help!
Answers 3
AB
AB 2018-08-05
for the vaccum I had:
Energy components:
                  Kinetic =      -54.4530301Ha
            Electrostatic =        6.3222606Ha
     Exchange-correlation =       11.1070958Ha
         DFT-D correction =       -0.2039073Ha
       Total DFT-D energy =    -4420.4093457Ha
Ef        -4420.409346Ha       -30.0451939Ha                1537.2m     11
Df  binding energy extrapolated to T=0K     -30.0198364 Ha      -816.88166 eV
FH
FH 2018-08-06
Hi, unfortunately it is not possible to calculate the free energy of solvation directly using COSMO. This method allows you to obtain the effects of a dielectric environment on the electronic structure of a molecule, but that is only part of the contribution to get the actual free energy of solvation. The entropic parts are missing completely from COSMO.
Using Forcite, it is possible to calculate solvation properties - you should have a look at the Forcite tutorials for more details.
AB
AB 2018-08-06
Thank you very much for your kind response.  All the best, AB
