How to build perovskite structure (FAPbI3).
I'm a beginner in material studio. I want to build FAPbI3 in cubic (pm3m). I have no issues in building PbI3. But how to insert FA molecule?
Usually position is (0,0,0) at at 4 corners. But I cant build FA in those corners? Please hep.
Thank you.
Answers 2
JL
JL 2021-06-22
You may consider the following procedure,
  1. Build the CsPbI3 structure based on your structure paper (use the actual cation in the paper if it’s not Cs).
  2. Read off the fractional coordinate of the Cs cation from the Property Explorer (Materials Studio interface > Dialogs > Dialogs in Properties Explorer > Edit position property dialog > Edit FractionalXYZ).  Be sure to select the cation, first, by clicking on it.
  3. In a new 3D Atomistic Document, build your FA molecule.  Create centroid for the molecule (Sketching and editing structures > Structure editing > Measuring and changing geometry > Measuring averaged geometries > Creating centroids).
  4. Make a copy of the molecule built above.
  5. Remove the Cs atom in the perovskite structure.  Paste the molecule into the perovskite structure.
  6. Locate and click on the centroid to select it.
  7. In the Property Explorer, replace the FractionalXYZ of the centroid with that of the Cs cation.  Apply the change.  Your molecule will be moved to the position of the former Cs cation.
Kind regards,
Jian-jie
VD
VD 2023-09-12
Extremely sorry for my delayed response. I had built the structure from github resources. Thank you so much for your support and information Jian-jie.
