How to build a metallic nano-cylinder?
Dear All,
I would like to build a nano-cylinder of metal such as Copper, Silver,...
Any one have suggestions about this issue? Please help me. Thank you very much!
Best Regards,
Truong Vo
Ulsan, South Korea
Answers 3
JD
JD 2015-05-08
Hi Truong Vo,
This is what we call a "nanocluster". You build it like this:
  1. Import Structuresmetalspure-metalsCu.msi
  2. Looks better in CPK style
  3. Build | Build Nanostructure | Nanocluster
  4. Shape = Cylinder
  5. Select desired radius and height
  6. Click Build
Best,
Jason
comment imagecomment imagecomment imagecomment image
BT
BT 2014-05-21
Dear Jason,
Thanks for your suggestions. In addition, I would like to create a circle hole through the pore. I uesd "Radial" in "Atom selection" to delete atoms. Is that a correct method?
I am looking forward to hearing from you
Best Regards,
Truong Vo
JD
JD 2014-05-23
Sure that will work. So to make a hole down the center axis, you can select ALL the atoms along the center axis and then use the Atom Selection dialog to add to that selection within a radius of your choice.
Another option is to align the axis of the nanotube to the screen and then use the lasso selection mode to select all the atoms in the center that you want. Lasso mode is done by holding down the Q key on your keyboard.
