in this file there is an atom name wat1 which is basically a oxygen atom to be bonded to a hydrogen atom so when I used COMPASS force field it is showing an error that wat1 is not an assigned atom. So I should dod it manually. But I am not able to do it manually. so if there is any one who can help me plz let me know.
The CIF file does not specify the chemical element of each atom. It looks like those labeled Wat1, Wat2, Wat3 and Wat6 are supposed to be the oxygen atoms from coordinated water molecules. But Materials Studio imports them as tungsten (W) atoms. You need to change them to oxygen, make symmetry P1 and add hydrogens. Then COMPASS should be able to type the atoms.
