I am working with a 8x8 Graphene sheet with a defect of a missing area at the center. After a day, it produces the following message reporting failure of the job. Can anyone suggest me to resolve it?
finite difference step for: atom 172 coordinate 2 step 1
cubic simple grid used for COSMO
Warning: small cosmo segm dist 10 195 89 2.4180 3.4773 -1.6610 0.1277 0.4268
Warning: small cosmo segm dist 41 823 1039 18.1786 -1.6974 2.0587 0.1216 0.4976
Warning: small cosmo segm dist 52 1042 1064 18.1580 -4.8871 -5.2108 0.0949 0.4344
Warning: small cosmo segm dist 53 1064 1042 18.2375 -4.8599 -5.1667 0.0949 0.3561
Warning: small cosmo segm dist 53 1065 1306 18.1657 -6.3312 0.9811 0.1519 0.5171
Warning: small cosmo segm dist 54 1086 1102 18.7622 -1.7043 2.0048 0.1274 0.4679
Warning: small cosmo segm dist 55 1105 1333 18.6888 -4.8294 -5.2413 0.0537 0.4660
Warning: small cosmo segm dist 58 1164 1182 30.2994 1.5968 -2.2332 0.0500 0.4737
Warning: small cosmo segm dist 59 1182 1164 30.3329 1.6182 -2.2030 0.0500 0.4438
Warning: small cosmo segm dist 66 1333 1105 18.6592 -4.7960 -5.2115 0.0537 0.4097
Warning: small cosmo segm dist 177 3855 2929 10.0917 23.6418 -1.8472 0.1611 0.5692
Many thanks in advance.
Thankfully
Keshab K. Adhikary
Hi, this is a standard warning and should not be the reason for your failure. Looks like you are doing vibrational calculations, presumably using coarse graining. Could it be that there are other error messages anywhere in the results? If run on a queue, can you make sure that the job didn't run out of time?
Dear Felix Hanbke, Thank you very much for reply. I resolved the problem.
