How can I run the successive Simulation by giving single command
I want to do successive steps of NVT by increasing 50k temperature in each steps. So I can't do it manually by giving input after the output each step, instead of it please tell other method like pearl script in which I can give the single command for that all successive simulation.
Answers 3
AC
AC 2021-10-01
Yes it is possible with perl script.
MM
MM 2022-06-14
can you do it?
TG
TG 2022-06-17
Dear Maliheh,
In fact, this task is even possible without scripting, using Forcite:
1. Open the Forcite Calculation Dialog
2. In Setup tab, select Anneal
3. Press the "More..." button, a second dialog opens
4. Configure increase of temperature of 50k in each step
5. Press the "More..." button in this second dialog
6. A third dialog opens, there you can select the NVT ensemble.
Hope this helps,
Best regards,
Théophile.
