I'm doing some simulation work with polymers and I've come across what, to me, seems like an arbitrary limitation on the chain lengths I can perform MD simulations on. Specifically, I seem to be having a problem with polymers containing heteroatoms.
Here's what I'm doing, feel free to try it yourself and see what happens for you:
1. Build a Nylon 6 polymer with the Polymer Builder (Build-->Build Polymers-->Homopolymer, amides library, nylon6 repeat unit).
2. Build two polymers, one that is 334 repeat units long and one that is 335 units long.
3. Run a simple Disco Dynamics run (see my error report below).
The 334 unit polymer runs fine, the 335 unit polymer returns the following error:
Error: Miscellaneous:
* In dyn_remove_momentum(), after removing angular momentum:
* C.O.M. of coords used = 0.000000 0.000000 -0.000000
* Adjusted linear momentum = -0.000000 0.000000 -0.000000
* Adjusted angular momentum = -1.255456 -0.100612 1.192369
invoked from within
"dynamics \\
time = 1000.00 \\
timestep = 1.00 \\
initial_temperature = 273.00 \\
ensemble = NVT \\
temperature_control_method = anderse ..."
Total time used by DISCOVER: 0.98 secs
The 334 unit molecule has 6,348 atoms while the 335 unit molecule has 6,367. The mass of each is around 37,900 g/mol which is a bit lower than I'd like.
What's the difference between 334 repeat units and 335 repeat units? I've been able to get MD simulations to run on 150,000 g/mol polystyrene molecules with no* problem.
Any input on the nature of the problem will be greatly appreciated -- I'm slowly hacking my way through Materials Studio and I love learning new things about it.
CS
