Geometry optimization process.
1. What is the difference between the CASTEP and FORCITE geometry optimization.
2. Big periodic systems the CASTEP takes more memory due to memory the calculation gets failed So can I use forcite  for such calculation
3. The optimized structure from forcite calculation can be used to calculate the properties in CASTEP ?.
4. what is the out put optimized structure file in both forcite and castep (XSD and XTD i am getting in castep)
Thank you very much
Answers 1
FH
FH 2016-03-16
Dear Ramesh,
1. They are fundamentally different. Forcite is based on force fields where each atom is a point source that has well-defined interactions with other atoms in the vicinity. CASTEP on the other hand is fully quantum mechanical and takes into account the electrons as well via their density in the framework of density functional theory (DFT).
2. This naturally means that CASTEP uses substantially more memory (you have to store lots of information on electrons which simply isn't there in forcite).
3. However, you may struggle calculating correct properties using CASTEP when you have a structure derived from Forcite - the compatibility of structures between both modules is not altogether trivial and requires careful benchmarking. Actually, if you can calculate properties in CASTEP then you are likely to have enough memory to do the structure calculation in CASTEP as well.
4. Please run some of the tutorials for both CASTEP and Forcite where these issues are explained in detail.
At this point, I'd stronly suggest that you spend some quality time with an introductory text on molecular simulations to help you define what type of problems you are trying to solve. This will then also help you determine the methods used (e.g. force fields vs electronic structure theory).
All the best,
Felix
