Geometry optimization not stopping after reaching convergence
Hello. I've been running into an issue with the geometry optimization not stopping even after reaching the energy and gradient convergence criteria. This is random, and sometimes it does stop. Most of the times, however, the optimization continues until the maximum number of steps is reached.  Here is the input file (I am using Materials Studio 2023):
# Task parameters        <--
Calculate                     optimize        <--
Opt_energy_convergence        2.0000e-005        <--
Opt_gradient_convergence      1.0000e-003 A        <--
Opt_displacement_convergence  1.0000e-006 A        <--
Opt_iterations                900        <--
Opt_max_displacement          0.03 A        <--
Opt_Scale_Vdw                 0.1        <--
Initial_hessian               improved        <--
Symmetry                      on        <--
Max_memory                    2048        <--
File_usage                    smart        <--
Scf_density_convergence       1.000000e-005        <--
Scf_charge_mixing             2.000000e-001        <--
Scf_diis                      6 pulay        <--
Scf_iterations                200        <--
# Electronic parameters        <--
Spin_polarization             unrestricted        <--
Spin                          0        <--
Charge                        1        <--
Basis                         dnp        <--
Pseudopotential               ecp        <--
Functional                    b3lyp        <--
Aux_density                   octupole        <--
Integration_grid              medium        <--
Occupation                    thermal 0.0050        <--
Cutoff_Global                 4.3000 angstrom        <--
# Internal constraints        <--
Opt_constraint        <--
93 85 0 0 2.222005
# Calculated properties        <--
Mulliken_analysis             charge        <--
Hirshfeld_analysis            charge
At the end of the file, all the steps have no change in energy and small gradient, like this:
       Cycle    Total Energy      Energy change   Max Gradient   Max Displacement
opt==  900        -1941.7472953      0.0000000        0.000027       0.000033
I realize the displacement convergence is very strict, and I do not plan for it to reach convergence, however, it should (and has for a long time) stop with only energy and gradient convergence, as I am not using the Opt_Converge_All option. If you could help me solve this issue, it would be much appreciated. Thank you in advance.
Answers 3
CM
CM 2026-01-15
Did you at least change these values:
I think that this is by far too tight (I doubt that it ever will be fulfilled):
I think that this is not tight enough:
I assume that the forces are not accurate enough with your SCF convergence settings.
Is this distance constraint fulfilled:
Opt_constraint        <--
93 85 0 0 2.222005
What happens if you use fine settings instead?
Please add the .zip file of such a run to the post:
Close all documents in Materials Studio.
Zip the complete folder of the run.
Add the resulting .zip file to the post.
Please also include the .xsd file from which the geometry optimization was started.
I suggest to use DFT semi-core pseudopotentials (DSPP) rather than Effective Core Potentials (ECPs).
JL
JL 2026-01-15
By fluctuating convergence, the program is actually trying to tell you that there are aspects about the structure/local chemistry that may have been overlooked/need attention.  Therefore, instead of worrying about (auto-) stopping the GO (geometry optimization), I’d manually stop the GO, and get the GO trajectory downloaded.  Play back those frames near the regime of convergence fluctuations, and see how the local structure jumps between the fluctuating configurations.  What’s the local chemistry involved?  Could there be, e.g.,  (barrier-less) positional disorder?  More importantly, how does such fluctuations relate to the overall structural chemistry of your research system?
The convergence fluctuation is a bucket of valuable information, not a nuisance.
Hope it helps,
Jian-jie
CM
CM 2026-01-27
Could you please reach out to your reseller and open a proper service request for this.
From all the things I did I think it is a bug and that this happens the the optimizer switches from delocalized internal coordinates to Cartesian coordinates.
