Geometry optimization choice of Force-Field
Hey all,
I'm trying to build an amorphous cell of Cyclohexane and water. for the initial geometry Optimization I'm not sure which force-field do I use. I tried COMPASS and dreiding for Cyclohexane and the the total energy is calculated to be negative for COMPASS. does it mean it's a better choice? I'd appreciate if anybody knows anything about the choice of force-field for different compositions.
Thanks,
Answers 1
CM
CM 2018-07-05
Energies between different forcefields cannot really be compared. Only energy differences are meaningful (e,g, between different conformers).
Ideally, you compare with experimental results and if they are not available with the results of QM calculations (energy and structure).
