generation radial distribution function (RDF)
I want to generate RDF from center of water to center of ethanol in my system (200 water + 200 ethanol), but dont know how do this. Can anyone help me?
In addition I want to generate RDF from oxygen of water to oxygen of ethanol, in this case what should I do?
Answers 4
JD
JD 2014-04-24
Hi Jab,
The RDF for oxygen atoms is easier. You create one set for the ethanol oxygens and one for the water oxygens and calculate RDF between these two sets.
To get the center-center RDF you need to create centroids and then again create a set with all the water centroids and a set with all of the ethanol centroids to run the RDF. To create the centroids, you would use a pattern search, where the pattern document would be either an ethanol with a centroid or a water with a centroid.
Best,
Jason
BJ
BJ 2015-05-08
Hi jdejoannis,
Can you explain the step by step procedure for me? First I selected one ethanol molecule and created centeroid to it, then from the Edit>Find Pattern I selected the ethanol with centroid and click find. I repeated the procedure for water. But when I want to create the RDF the error display. I have attache the realted file.
comment imagecomment imagecomment imagecomment image
JD
JD 2014-04-25
With the pattern document, make sure you have the centroid selected. Then click Find Pattern - it should result in one centroid being created for every molecule of that kind. Now right-click and choose Select Substructure Items and create a set, eg, "etoh_centers".
BJ
BJ 2014-04-26
Thanks a lot. It was so helpful. Finally I draw it.
Best Regards
