I tried to use the sorption module in materials studio to study the adsorption isotherm of carbon dioxide on FUA zeolite with a silicon aluminum ratio of 1:1. FUA zeolite has balanced its charge by adding Na+. But the final results indicate that the carbon dioxide adsorption capacity of my model is much lower than the carbon dioxide adsorption capacity in the literature. (For example, under conditions of 293K and 200kpa, FUA adsorbs 25 carbon dioxide molecules, while the actual adsorption can reach around 55 carbon dioxide molecules) I don't know what happened. The original file is below. Can anyone help me answer this?
I found that this may be related to the charge of each atom in my zeolite skeleton and carbon dioxide molecule. I don't know how to allocate how many values to them, so I used the position automatic allocation charge. However, the calculation results show that the entire skeleton carries 96 charges after the force field is automatically allocated, but it is clear that the zeolite skeleton is not charged after the sodium ion equilibrium, Can anyone provide an answer on how to allocate a charge?
Do you have the DOI of the paper(s) to which you refer.
From time to time I tried to use this procedure do get a neutral system:
1. Open Forcite Calculation.
2. On the Energy tab set the forcefield to COMPASSIII
3. Click the More button.
4. Uncheck Calculate automatically.
5. Make sure that the charges are set to Forcefield assigned.
6. Hit the Calculate button.
7. Open Modify->Charges.
8. There navigate to the Edit tab.
9. Select the Set total charge to: radio button
10. Make sure that the value there is zero.
11. Hit the assign button.
At least in theory that should result in a neutral system. I am not sure if I ever tried to use QM charges (Hirshfeld) here and which difference that made to the results.
When you now use the structure in Sorption or Forcite makes sure that:
1. COMPASSIII is the selected forcefield.
2. The charges field is set to Use current.
3. Calculate automatically is unchecked (paranoid, not really needed because that hopefully always gives the same result for the same forcefield).
4. proper charges are really assigned.
Any other idea or suggestion is appreciated.
Hi, the attached run has 1000 equilibration steps. I think this is insufficient as the loading profile is still showing an increase; it should fluctuate around an average value. The cited paper uses 1 000 000 equilibration steps, which might explain the higher loading observed.
