Hi, All.
I'm using Materials Studio 2021 and recently had a batch update of windows 10 on that PC.
After this update, the phenomenon that the screen of Materials Studio Visualizer freezes and does not work has come to occur frequently.
At that time, the memory usage fee is about 30%, even though the CPU is almost unused.
Since SystemRequirement only describes the OS version, I have no idea how to improve this situation.
Could someone lend me some wisdom?
※Append
I found this(In my environment).
If OS build of windows10 is 18363.1500 then, move.
If OS build of windows10 is 19042.985 then, don't move...
My WIndows 10 version is Chinese, and I think this is MS is incompatibility with latest Windows 10. I also faced this problem and fixed by turn on the previous version of Microsoft IME.
Try using the previous version of Microsoft IME.
Kuroki-san, is there a pattern to the actions you perform before visualizer freezes? For example, do you manipulate the structure, or enter values in the text fields on the user interface, or copy/paste, etc.?
Thank you for responses!!
戴 世宣-sama.
Thank you for telling me the workaround.
The phenomenon occurring in your environment may be similar to or related to yours.
Victor MILMAN-sama.
The pattern of behavior is not limited, but you make a few clicks (which fits 3-5 times each time).
This action (which applies to almost any action on the GUI, such as opening an xsd file, opening a toolbar, expanding a project folder, opening a Calculate dialog, etc.) will confidently freeze.
For example, open the structure file, rotate the displayed structure to observe the structure, open the Calculate dialog, and press Run. It was unlikely that this operation would be completed successfully.
So, 戴 世宣-sama's advice is very helpful.
Sincerely.
