Forcite - No intermediate results available yet
I have been running NPT simulations in Forcite. This has been running successfully for >1us so far, however on the most recent Restart, the job "completes" instantly, and I get this message in Status.txt: "No intermediate results available yet!". There are no error messages in the log file, and no outputs (energies, density etc). Can anyone help?
Answers 4
JL
JL 2025-05-27
Just in case you didn’t notice, restarting an MD simulation requires uploading the entire trajectory generated in the previously terminated MD job (to be restarted).  Given you were collecting data in us scale, your trajectory must be huge, and may cause difficulty uploading to your server for the restarting job, hence the strange behavior.
One alternative can be to start a new MD data collection, from the last frame of the trajectory in the previous episode, instead of restarting.  You can then, e.g., concatenate the trajectories in post processing.
Hope it helps,
Jian-jie
MD
MD 2025-05-27
Hi Jian-jie, thanks for the suggestion. The trajectory is broken up into multiple steps of  30ns e.g. running 30ns, then restarting from here etc.
I am unsure about starting an entire new simulation from the last frame as the simulation consists of a temperature ramp, where the thermal history is important. If I understand correctly the energies/ forces etc would be randomised at the start of the new run which could affect the results(?). Ideally I would continue from where I left off, though I will try this if I cannot sort the problem.
Thanks again.
JL
JL 2025-05-28
Hi Michael,
In such case, you’ll want to use the following combination in restarting your MD job, under the “Restart” section in your job setup,
-check “Restart”
-not check “Append to current trajectory”
This combination will a) restart the MD job with Initial velocities From restart; and b) existing trajectory will not need to be uploaded for the restart.
This way, the initial velocities, hence the associated temperature, will be continued from where the job was previously terminated.
Best Regards,
Jian-jie
MD
MD 2025-05-29
Hi Jian-jie
This is what I am already doing, but thanks again for the suggestion.
Michael
