When using Geometry Optimization or Energy calculations in Forcite, there is an option to check for Hessian. According to the manual, it is supposed to output a Hessian, but no Hessian files or output can be found. Does this feature work or produce any output?
It creates the Hessian Matrix so that you can use that for Vibrational Analysis. This is the easiest way to create the Hessian without running a QM calculation to do so.
Hi Josh,
As you noticed, the Hessian matrix had been incorporated into the result .xsd file. One can export the .xsd file in .hessian format (File | Export | Save as type => *.hessian).
Much thanks to Reinier who pointed this option out.
--Jian-jie
