Hello everyone,
I aim to calculate the interaction energy between PEDOT:PSS and other components; however, it cannot be modeled as a unified entity to construct the "confined layer".Could you please advise on how I should resolve this issue?
Looking to you reply
Yi Mu
As it says in the message: the backbone definition in the molecules/polymer chains is is not contiguous.
When you switch the display style for atoms to Backbone for document 3 you might see where the problem is and if there are tqo (or more) backbone segments in the molecule.
You have to select the atom(s) which you want to use as backbone atoms and in the Properties Explorer you can set the IsBackboneAtom parameter to Yes for those atoms.
I assume that this is the 3 structure which is defined in the Amorphous Cell Composition dialogue where you add molecules.
I get the same error message when I set IsBackboneAtom to No for backbone atoms in Polyethylene which was build using Build > Build Polymer > Homopolymer
The pink? atoms are backbone atoms. The grey atoms in the polymer chain are the atoms where IsBackboneAtom was set to No
