I am encountered with the following error:
Error: Forcefield: Encountered the error - was expecting a '#' line, on line #2
Can any one tell me what it is about?
Can u please upload or paste the joblog file or status.txt file where we can find much information.
I think the information provided by you at line #2 is not sufficent.
thanks for your reply
#BIOSYM btcl 3
# Input File For Discover Generated By Materials Studio
# Input Client Model Document: C:\Documents and Settings\saeed\My Documents\Materials Studio Projects\Untitled Files\Documents\Nanocluster.xsd
# Job: [2XB3Y] - Nanocluster Disco Energy
autoEcho off
# Begin Forcefield Section
begin forcefield = pcff
# Nonbond section:
forcefield nonbond \
-separate_coulomb \
vdw \
summation_method = atom_based \
cutoff = 9.50 \
spline_width = 1.00 \
buffer_width = 0.50 \
coulomb \
dielectric_value = 1.0000
# End Forcefield Section
# Single Point Energy section:
energy print +energies
Have you checked the more option which is present beside the ForceField Drop down menu where u can check the selected forcefield is correctly accessing the required .FRC file from the Material studio installation Directory. (Compass forcefield should map compass forcefield files in the installation directory).
I would really ask you to perform same minimization using COMPASS forcefields. (This is to check it might be a problem with assignment of Partical Charges to the atoms).
Hello
thanks for your answer
I have already checked the COMPASS. but it makes no different.
and if you check the PCFF and COMPASS. the structure of the .FRC files are somehow the same.
the only difference is the element type with their forcefield, each have.
regards
Hi Saeid,
How did you run this Discover calculation? Did you run it in a standalone mode or through the interface?
Thanks, Alex.
