I'm having a lot of problems with the connection between the server (which in on my workstation) and the client.
Start tests for host localhost, port 18888
IP address is 127.0.0.1
Ping result = Success
Ping round trip time was 0 msecs
Test connection to
Error in http test:
Value does not fall within the expected range.
Tests failed
Test connection to http://localhost:18888/
Error in http test:
Tests failed
Normally there should be a Gateway location "My Computer" when client and server are the same machine which should be used to make runs on localhost.
I'm using Materials Studio version 6.1.200
on Windows 7 Enterprise SP1 64bit.
I am using the My Computer Gateway to localhost.
Did you change any of teh gateway data?
What happens when you connect to
https://localhost:18888/
Coud you please post
C:\Users\carsten\AppData\Roaming\Accelrys\Materials Studio\6.1\DSM\Daemons\My Computer\My Computer.sbd
