Effective use of Study Tables?
Materials Studio can create study tables, where I directly can refer/insert structures and trajectories. The documentation says I can insert data by copy-insert, too, but I cannot find other ways. Is it possible to automatically populate the table with data, so if I refer to a structure if there a way to automatically extract some specific properties, like energy, charges of given atoms or geometry?
Answers 5
CM
CM 2018-06-25
Some things can be done as QSAR descriptors on the QSAR tool bar if you have QSAR licensed.
JD
JD 2018-06-25
Yes the QSAR Models button has lots of options for generating properties from structures in the study table. This can also be done with scripting and is rather a standard practice if you look at many of the sample scripts in this forum.
FH
FH 2018-06-26
In addition, it may be an idea for you to write a short script that extracts exactly what you want and then turn that into a user menu. There is a tutorial on how to do this (Tutorials | Scripting | Executing scripts from the user menu). Setting up a script is usually very straight forward, you have full access to the study table and its containing structures, and may be an option if QSAR does not give you exactly what you want. Otherwise I agree with Carsten and Jason that QSAR should be your first option.
GJ
GJ 2018-06-26
Unfortunately, I have no QSAR licence, but thank you very much for the pointing towards scripting.
RA
RA 2018-06-29
Forcite’s View in study table analysis provides a quick way to get all trajectory data (energies, cell parameters etc) in a study table.
