Dear All,
I have constructed a cell of length=100Angstrom ,packed it with a polymer and solvent molecules.Is it possible to perform an NVT run at 1 atm pressure?How do we set the pressure to 1 atm in NVT run?
Thanks a lot for your time and consideration.
To run NVT at 1 atm, you first need to determine the volume V that will result in p(N,V,T) = 1 atm, for example by running a series of volumes V1, V2, … and measuring p(N,V1,T), p(N,V2,T), …. You can then estimate which V would give p(N,V,T) = 1 atm.
More straightforward would be to run NpT where p = 1 atm (i.e. 0.000101325 GPa), and measure the average volume V(N,p,T). If you run NVT with this volume, you should find p = 1 atm.
Note that in practice the fluctuations in pressure are much larger than 1 atm, see this topic.
