Hi All,
I'm trying to build a system of oil and water ( and surfactant) emulsion to analyse the effect of different oil molecule structures or different surfactants. in the Mesostructure template should I add a droplet or a slab to the cell, as I've seen both to be used?
Thanks,
Hi Fatemeh,
Slab systems can be used to calculate surface tension and interfacial tension. Droplet systems can be used to determine the contact angle. Also you can start from a simple box template to generate a random mixture and see what morphology evolves as a function of concentration and temperature.
thanks so much for your clarification Jason
