Difficulty in building Nafion-based PEM system in Materials Studio
I am trying to build a realistic Nafion-based PEM system (polymer + water + hydronium) using Amorphous Cell + MD in Materials Studio.
Polymer details:
  • Fluorinated backbone (–CF₂–CF–)
  • Side chains with –SO₃H groups
  • Water and H₃O⁺ are added separately during amorphous cell construction
  • Approx. composition: C109 H12 O60 F208 S12
    Amorphous packing Gives:
  • Poor distribution
  • Most Atoms outside the box
  • Unstable structure after MD Run
    After MD run the atoms are moving out of the box.
    Also Is there any other approach for this work?
Answers 2
JD
JD 2026-08-03
Hi Yash,
  • It is normal that "atoms are moving out of the box". Periodic boundary conditions.
  • Regarding "poor distribution": I doubt it. How do you know, just visually? You can also build larger systems and multiple cells to get a statistical sampling.
  • Why do you say that the structure is unstable? Did Forcite throw an error? What was it?
TM
TM 2026-08-04
As Jason said, were any error messages output indicating that the job had terminated abnormally? If yes, please copy&paste it to the article.
If no, the problem might simply be the appearance. Open the structure file of interest, open the Display Style dialog, move to the Lattice tab, then select Style: In-Cell to show atoms and image atoms only in the periodic boundary. It is the structure you will investigate. If it still looks poor distribution and/or unstable, please attach the initial structure of molecules and all files output by Amorphous Cell.
Did the structure contain counter charge for H3O+? It is generally SO3- included in Nafion. If not, the structure is on Jellium background, which may be unrealistic for organic system. I recommend to investigate previous researches similar to yours.
