Is there a method to define two distinct terms for the same atoms involved in an angle bending scenario? Specifically, consider the angle between O-Cu-O atoms. I would like to establish force field angle bending terms for both 120 degrees and 180 degrees, like so:
O Cu O 120deg O Cu O 180deg
Unfortunately, achieving this directly within off force field files seems to be impossible (MS simply won't allow it). I'm exploring alternative approaches to accomplish this. One working solution I've implemented involves identifying which oxygen atoms are part of the 180-degree angle (O-Cu-O angle in this case is perpendicular to the CuO3 plane) and assigning a different force field type to them. While this approach works, it's not particularly elegant as it results in different force field types for essentially the same atoms. I'm curious if there's a more refined or efficient way to achieve this within off force field. Any insights would be greatly appreciated.
Best wishes,
Bojan
Hi Bojan,
You could use a tabulated potential for this, with minima at 120 and 180°.
Alternatively, you can turn a quartic function into a double well potential by choosing parameters appropriately (specifically, T0 = 120, C = −6/π and D = 9/π², gives minima at 120 and 180°).
Good luck,
Reinier
Dear Bojan:
Have you considered typing the Cu atom differently in different environment? You may find similar approach for Al in silicates, where Al can either be tetrahedrally or octahedrally coordinated, and hence the O-Al-O angles defined differently.
Hope it helps,
Jian-jie
Dear Jian-Jie,
Thank you for your message, I appreciate your time. I took a quick look at both Dreiding and UFF based on your suggestion. Meanwhile, I've implemented a straightforward tabulated potential in my *.off file, allowing me to define any functional form and minima. For the specific angle of interest, which exhibits two minima at 120 and 180 degrees, I've adopted a standard approach by using harmonics for both angles. I set the equilibrium angle to 120 until half the difference between 180 and 120, and then switched to an equilibrium of 180. While this approach generally requires caution, it's safe enough for crystalline materials, as the likelihood of an angle intended to be around 120 deg switching to 180 deg during the simulation is practically nonexistent.
Do you happen to know which ff could be a good reference for silicates that you've mentioned?
Thanks once again.
Best wishes,
Bojan
