Density change with temperature
I have constructed a polyimide structure. After long equilibration procedure with different ensembles, ı run 2 ns NPT at 308K nad 298K. The average density of the unit cells are 1.273 g/cc at 298K and 1.280 g/cc at 308K. I assumed to be the opposite.  I think that it should be more dense at small temperatures, but it does not. And also there should be large difference than 0.007 g/cc between 298K and 308K. I totaly confused, I made a mistake in somewhere, but I could not find it. I attached my structure, if you can help me , I will be very pleased. Thanks a lot.
Answers 1
HP
HP 2012-06-05
I've noted the same difficulty with relaxing polymers at different temperatures. I think the problem is that the thermostats usually can't accurately control the temperature but varies (even when the structure is fully relaxed) between +- 5 to 10 K anyway. So, I'm not sure if there's a better solution to this but I've found that by increasing the temperature increments to 50 K you get a more realistic variation of density with temperature.
Not sure if this helps.
