How can I build a dendrimer while my seed and repeat unit are the same. Once seed and repeating units both are set to "selection" the bulid button is grade out!
1
JD 2015-11-24
Hi Tari, A valid seed structure must have at least one "connection point" linkage defined. A valid repeat unit structure must have at least one "head" linkage defined. To definte these linkages, use the Connection Points tab on the Build | Dendrimer dialog.
