There is currently a Tersoff type forcefield in GULP for two-body interactions. If I wanted to implement a Tersoff type potential for three-body interactions what is the syntax in the forcefield file? An example of the two-body is given below:
H core H core 86.71200 43.5310 3.78790 1.9800 0.8000 1.0000
Is it simple enough to write:
H core H core H core---- followed by the proper coefficients in the Tersoff forcefield?
Thanks in advance!
NS
Thanks in advance!
NS
Please search the help for that to find the correct syntax.
On a first glance it looks o.k. (seems even be for the Tersoff forcefield file) if you also use the BOTWOBODY keyword to tell the parser that such a functional form comes now.
botwobody - this gives the parameters that control the simple two-body exponential part.
borepulsive/boattractive - these give the repulsive and attractive bond-order parameters, though usually only the attractive term has a bond-order contribution.
The three-body contribution in the Tersoff model is actually part of the bond-order contribution and is specified by using "boattractive theta", for example.
An example of how to specify the Tersoff model is given in the library file "tersoff.lib" that comes with the program. Cut down to show the example of H only this would look like:
botwobody
H core H core 86.71200 43.5310 3.78790 1.98 0.80 1.0
borepulsive
H core H core 0.0 3 1.0 1.98
boattractive theta
Full details of what the parameters are and the units are given in the help.txt file or on line at:H core H core 4.0 3 1.0 1.98 0.0 1.0 1.0
nanochemistry.curtin.edu.au/gulp/help/manuals.cfm
