Create vacuum layer for equilibrated polymer cell
For a polymer structure created via Amorphous cell (created with confined layer), I would like to equilibrate the polymer system first before combining with other components. However, the polymer atom will cross the PBC after complete equlibration. How can we transfer them to other systems without the atom crossing the PBC? For example, transferring them between 2 layers of water molecule, or above a solid surface layer, etc...
Answers 4
JL
JL 2026-06-18
For your purpose, you’ll want to use the layer builder to confine your polymer (slab) accordingly. Refer to the tutorial,
Tutorials > Visualizer tutorials > Using the layer builder
Hope it helps,
Jian-jie
CM
CM 2026-06-18
- Define a model with "some" graphene layers  from graphite model. It should be larger than the layer you already have.
- Use the Layer builder to put both layers together and use the dimensions of your system
As long as you fix the graphene layer it should not matter how it looks.
What do you want to do with it at the end?
The surface which you will get for your system may be influenced by the graphene layer and the other side of the layer. I never looks deeper into this effect.
Could you please end me in a private communication the LKO# which you find in your license file (or even the complete license file).
CM
CM 2026-06-22
The polymer slab definitely will interact with the graphene layer and itself. This is what I meant with this:
MM
MM 2026-06-25
you can look at this paper: Meunier, M., A. Goupil, and P. J. I. J. P. Lienard. "Predicting drug loading in PLA-PEG nanoparticles." International journal of pharmaceutics 526.1-2 (2017): 157-166. section 3.1. Building PLA surfaces - less efficient but works Ok too.
