This script enables you to create a trajectory which shows the rotation of an existing trajectory. It can be used, for example, to create a movie of a vibrational mode being rotated.
As with the previous "Create a trajectory of a rotating molecule" script, this is limited to molecules and will not work with 2D or 3D periodic structures.
Minimum version: Materials Studio 5.0
Modules used: Materials Visualizer
Cheers
Stephen
If there are two separate molecule in this trajectory, and i just modified the original script, let each molecule rotate clockwise or counter-clockwise, so the interaction face between the two molecules are changing.
After rotating a trajectory file using this script, you know each molecule in the original xsd extension file in original every frame has been rotated by certain degree clockwise or counter-clockwise, and the questions are:
1. Do you think the atoms properties such as force will change automatically and correspondingly ? Since the relative position of atoms from different molecule changes, the interaction energy between atoms also changes, so the force imposed on each atom should become different.
2. you know, If the original trajectory file is abtained from running a dynamics simulation, Can the generated trajectory be also seen as a dynamics process? (Comparing to static dynamics which is usually obtained under 0 K)
Thanks a lot in advance!
Look forward to your reply in your due course.
Best reagrds,
Wesley
2. I am not clear what you mean by "static dynamics". If you run a molecular dynamics simulation, you need to specify a temperature and the simulation results show the motion of the atoms at that temperature.
Cheers
Stephen
Thank you very much for your reply.
Best regards,
Wesley
