Copy molecules with bonds
Dear all,
When copy a set of atoms to a xsd file, I always had atoms and 1bonds. Recently, I can only copy atoms. Do you know why? And how to copy both atoms and bonds?
Best,
Trang
Answers 4
CM
CM 2022-05-18
This is scripting or manual copying?
How exactly do you copy the molecule?
Does the system molecules defined and does it work to copy the molecules instead of a set of atoms?
VN
VN 2022-05-18
Hi Carsten,
1. This is manual copying
2. Select sets and copy
3. The system molecules were not defined. If I copy a single molecule, it works.
JD
JD 2022-05-18
Hi Trang, Your set probably does not include the bonds. When you select it, do you see yellow selection markers on atoms and bonds or just the atoms? Try this: select your atoms and then right-click and select fragment. Now you can create a new set that includes the bonds or copy and paste.
VN
VN 2022-05-19
Hi Jason, thank you! It works.
