Dear DMol3 users and developers,
I have a couple of questions regarding setting up and converging DFT calculations to a given spin state.
To be specific, I have performed geometry optimization (blyp functional + vpsr pseudopotntial) on the adsorption of hydroxyl (OH) on some organometallic molecules with one Co atom in the center. I have started calculations setting up several spin states (Spin "nr. of unpaired electrons", Occupation fermi) flags in the input, see the input below. However, whatever Spin value I set up it always converges to the same configuration with 2 unpaired electrons. This would be fine; although I tried to calculate singlet spin state by forcing calculation to be spin restricted (since the Spin flag appears to not work) and got configuration lower in energy by 0.6 eV that the one resulted from unrestricted calculations.
Therefore my questions are:
If Dmol3 converges to the lowest spin configurations is there any reason that could fail to find that this lowest energy singlet state as in this example?
Why Spin flag in input appears not to work?
I would be grateful for your comments and suggestion.
Thank you in advance,
Jakub
I am using Dmol3 v 6.0
Input file I use (for singlet state)
# Task parameters
Calculate optimize
Opt_energy_convergence 1.0000e-005
Opt_gradient_convergence 2.0000e-003 A
Opt_displacement_convergence 5.0000e-003 A
Opt_iterations 300
Opt_max_displacement 0.3000 A
Initial_hessian improved
Symmetry off
# Electronic parameters
Spin_polarization unrestricted
Spin 0
Charge 0
Basis dnp
basis_version basfile_v4.4
Pseudopotential vpsr
Functional blyp
Aux_density octupole
Integration_grid fine
Occupation fermi
Cutoff_Global 4.5000 angstrom
Scf_density_convergence 1.0000e-005
Scf_charge_mixing 0.1000
Scf_spin_mixing 0.3000
Scf_iterations 343
Scf_diis 6 kresse
# Print options
Print eigval_last_it
# Calculated properties
Plot spindensity
Mulliken_analysis charge
Hirshfeld_analysis charge
Frequency_analysis off
Grid msbox 3 0.2500 0.2500 0.2500 3.0000
final occupancy from .occup file
257 1.000000 1.000000 a
2 1.000000 0.000000 a
0
