I am trying to construct graphene oxide (GO) models in BIOVIA Materials Studio for Flory–Huggins χ screening.
Could you please guide on the correct approach to generate Low, Medium, and High oxidation GO structures? Specifically, how to quantitatively control the O/C ratio and incorporate a realistic distribution of functional groups (–OH, epoxide, –COOH) on the graphene sheet, while maintaining structural stability for MD simulations?
Dear Yash,
Thanks for writing in the community. What do you mean by quantitatively controlling the ratio? Are you seeking an automated approach to functionalize the graphene oxide surface?
You might find the following page from the help useful (Help > Help Topics in Materials Studio visualizer):
Tutorials > DMol3 tutorials > Effective Screening Medium (ESM) calculation in DMol3 (shows how to build a graphene sheet)
Hope it helps,
Best regards,
Théophile.
You have to write a script which does this.
A good starting point is the script which Jason posted in this discussion:
For the epoxide I have the following idea:
* Loop over all H.
* identify the O which is connected to it.
* Identify the C which is connected to the O
* Loop over all C which are connected to the C of the OH group.
* Randomly make a bond between the O and one of the three C
It might need additional logic to prevent that a connection is made to a C which already has an OH group connected or is already part of an epoxide
I do not have a good idea for COOH right now, perhaps something like:
* Make the O of the OH group a C.
* Make the H an O
* Add an O the same/similar way as it is done in the script to get COOH.
I see some pitfalls here and I think it is a good idea to give the atoms unique names to prevent that an O from a COOH group is modified again later on.
Hi Yash, I managed to create the attached example using two scripts posted here in the community.
I had to change the script a little to get it to work with periodic systems, so attached is an updated version of the script as well as my inputs and outputs.
