Cohesive Energy of a Carbon Nanotube
I was wondering if anyone knows how to find the cohesive energy of a carbon nanotube in Materials Studio?
Thanks,
Raymond
Answers 3
BM
BM 2014-06-28
Hi
Cohesive energy density CED is the energy needed to remove a given molecule from its neighbors. It is related to the heat (or Enthalpy) of vaporization which is the quantity of heat that must be absorbed if a certain quantity of liquid is vaporized. Though there is a Forcite CED task, I can see several problems.
1) The CED calculation is valid for liquids. At atmospheric pressure carbon nanotubes has no melting point and is a solid.
2) The CED calculation works on molecules. Nanotubes are infinite chains.
Perhaps an estimate could be made by making carbon nanotubes in a periodic box, cutting them at a known length and hydrogen capping it? Then performing a Forcite CED calculation. Then repeat with a longer molecule and if the approach is valid the answer may converge. I'm a software engineer with some experience of modeling and not  a Chemist or Physicist so I don't know how valid this approach would be!
Regards
Simon
BS
BS 2014-06-30
Thank you for the information and advice!  I will see where this will take me, it seems like a plausible approach.
Thanks again!
Raymond
RA
RA 2015-05-08
Hi Raymond,
In [1] the cohesive energy of a nanotube was estimated as the energy of isolating a tube from a bundle of tubes. The resulting solubility parameter is a reasonably smooth function of the tube diameter, independent of chirality, from which polymer miscibility may be predicted:
Regards,
Reinier
[1] A. Maiti, J. Wescott, P. Kung, Nanotube-polymer composites: insights from Flory-Huggins theory and mesoscale simulations, Molecular Simulation, Volume 31, Issue 2-3, 2005
comment imagecomment imagecomment imagecomment image
