I am trying to simulate the effect of water addition on the mechanical and thermal properties of chitosan/PLA blend but stuck at getting the appropriate chitosan 3D structure. Also, I will really appreciate if anyone could guide me through the protocols to predict the mechanical, thermal and tribological properties of Polymer filled with nanofillers. Thanks
What is the appropriate chitosan 3D structure for you?
The structure of the Chitosan monomer or the cell which you build afterwards?
Where did you get that picture from?
This is neither a monomer or a cell -> What are you really after?
Anyway, my suggestion would be to build the monomer using the structure in Wikipedia (https://en.wikipedia.org/wiki/Chitosan please double check that the structure is correct)
and then build you n-mer(s) yourself.
Make sure that you are familiar with the functionality which is covered by the "Using the polymer builder" tutorial.
