I am trying to perform a band structure calculation with CASTEP. The calculation fails with an error, which I cannot understand.
" Trapped SIGINT or SIGTERM. Exiting...
forrtl: No such file or directory
forrtl: severe (28): CLOSE error, unit 11, file "Unknown""
Server details: 80 cores, 1 TB HDD, 700 GB RAM, CentOS 7
I attached the relevant files. Any help is appreciated.
Which CentOS release is this exactly?
Where the *.param or .cell files edited manually?
The job was started with opt_strategy : Speed
What happens when the job is prepared with "Default" settings for Runtime optimization (opt_strategy : Default)?
Is there anything else in the *.log or *.txt fies or in the log files of the single threads?
The CentOS release is:
CentOS Linux release 7.7.1908 (Core)
core-4.1-amd64:core-4.1-noarch
The input files were not edited.
The error also occurs on other runtime optimizations (I can reprocude the error with different calculations, too. See my last post.)
The logs of the threads are empty. The "todsd.txt" states "
1577976616 status new setup
1577976645 status new starting
1577976646 status new running
1577976646 status new queued
1577976647 progress -1
1577976650 status new running
1579135859 progress 100
1579135859 message error Trapped SIGINT or SIGTERM. Exiting...
1579135859 status new failure-completed
I do not understand this:I can reprocude the error with different calculations, too. See my last post
Do you refer to this post: CASTEP GO fails after SCF completed successfully
Do you also have a smaller example (as small as possible)?
I also suggest to see if Materials Studio 2020 behaves differently.
Is this a cluster or an SMP machine?
Is NFS (or similar) involved at some point?
Is there perhaps something in the system logs?
I just wanted to say, that I can reproduce this type of error with different runtime optimizations or CASTEP tasks. And yes, I referred to "CASTEP GO fails after SCF completed successfully". In that topic I was advised to use more computational power/ hard drive capacity.
Do mean smaller example with regard to the number of atoms or simulation box? My calculations are all above 100 atoms per cell.
I will set up a Materials Studio 2020 calculation in the next days.
The calculation was performed on a SMP machine. It has its own hard drive. NFS is not involved. I did not find anything in the system log. Do you have a hint for me for which things I should screen the system logs?
