Can we create dummy atom in Materials Studio?
I want to create a polymer layer with large vacuum at the upper and lower region and put some water molecules at the lower region to let them diffuse through polymer layer into upper region. As the water molecules at the lower region can move across the Periodic Boundary, I plan to create a dummy atom layer at the lower part to prevent such movement.
Questions:
1. Is it possible to create dummy atom in Materials Studio?
2. I try to use a graphene layer as alternative option now and freeze their coordinate, but the polymer (PE layer) in middle region will experience drifting and attracted to the graphene layer under NVT ensemble... What's the best way to avoid this?
Answers 4
CM
CM 2026-04-29
Materials Studio does not really have dummy atoms. Definitely not for molecular dynamics.
JL
JL 2026-04-29
Indeed, introducing foreign species (graphene in your case) tends to alter the nature of your simulation model, and should be avoided.  You’ll want to consider forced diffusion, instead, by, e.g., applying directional initial velocities for your water molecule(s).   I’d suggest to start with the BIOVIA Reference Center,  searching for refs on forced diffusion, and see how fellow researchers are approaching the subject matter.
Hope it helps,
Jian-jie
JD
JD 2026-04-29
Via scripting there is an option to impose an external force on a set of atoms. Here is the UI have created to illustrate the options available.
You can see there is an option to counter the external force. That would be good for you since it would apply an equal and opposite force to the polymer layer, which would prevent it from being pushed around by the water molecules. The Help system contains a page (Forcite > Theory in Forcite > Electric fields and external forces) describing how to extrapolate to obtain the unforced diffusion coefficent.
If you prefer to study unforced diffusion, then you can add restraints or constraints to some of the atoms of your polymer layer and make sure it is far enough from the graphene layer (eg, larger than the nonbond cutoff) to avoid interactions. You could build it out of something like argon or xeon so it is less sticky for the water molecules.
comment imagecomment imagecomment imagecomment image
MM
MM 2026-06-25
why not creating a model with Vacuum-Polymer-Water-Polymer-Vacuum? like this the water will have to go through the polymer membrane - left or right - before 'evaporating' in the vacuum region.
