Calculation of the calorific value of the material
Dear teachers and MS technical engineers in the community,
I have been using MS software for nearly eight years, and recently encountered a problem in the process of using, which module of MS software should be used to calculate the calorific value of materials? I have been looking up information without relevant detailed steps, but also hope that the experts are generous, the more detailed the better, because I am very stupid, thank you!
Good luck,
YunLiu MU.
Answers 3
CM
CM 2024-02-23
What is the caloric value for you?
Could you please describe it a bit closer.
What do you want to do with it afterwards?
I am not a native speaker and when I translate it it can have multiple meanings.
CM
CM 2024-02-23
You have to set up the equation for the combustion reaction and then calculate the energy difference between the reactants and products. So calculate the heat of reaction.
Which product do you want to use for this, do you have access to?
CM
CM 2024-02-27
Please have a look at the "Calculating the free energies of chemical reactions" tutorial.
The definition is here:
https://en.wikipedia.org/wiki/Heat_of_combustion
and here you have even the combustion of CH4:
https://simple.wikipedia.org/wiki/Heat_of_combustion
I also suggest to search here to see what others did:
https://www.3ds.com/products/biovia/reference-center
