Building SAMS
what is the best way to build self-assembled monolayers (SAMS) with Materials Studio 3.4?
I would like to build a gold surface and adsorb some mercapto-alkanes on it.
Thanks
Timo Schüler
Answers 2
GD
GD 2009-03-11
This is how I do in MS 4.0 or higher. I didnt use MS 3.4 and if you already know how to build SAMS in versions after 4.0 then please ignore the following message.
Import the gold structure file from MS library. Extend the unit cell in three lattice directions (lets say 3x3x3).. Then make it a super cell and cleave the surface to expose whichever plane you want to use.
Once you have a surface..leave some vacuum space above the surface and build a 3D box. Now you can place the thiol molecule on the surface on top of bridge or hollow sites.
Cheers,
Phani
MM
MM 2009-03-11
quote:
mercapto-alkanes
Hi Timo,
Once you have cleaved the surface using the surface builder in the visualiser, you can also adsorb multiple molecules onto the surface via a monte carlo simulation using a tool called adsorption locator.
If you would like to calculate the interactions with a complete layer of alkanes, you could also try building a cell of alkanes and then using the layer builder to bind it on top of the cleaved surface.
Hope that helps.
Manisha
