Blends calculation - periodic boundary condition
Hi everyone,
In the past I have performed calculations on polymer blends using the Blends module.
As an input I have used the repeating units and I have defined the head and tail units as "non-contact".
Does the blends module make use of periodic boundary conditions?
Does the blends calculation give an idea about possible interactions between polymers where you need a certain minimum sequence length? (i.e. polymer-polymer complexes which require a chain of at least 7 monomers length)?
Thanks!
Answers 1
JD
JD 2017-11-07
Hi maja18,
No to both questions. It is a simple model of binary interactions.
Jason
