Hello everyone,
I am new to BIOVIA. Do you have any specific recommendations with regard to running the software in Amazon EC2?
I also discovered that the requirements for the back-end Biovia pieces, Direct and Pipeline Pilot, include having an Oracle SE or EE database. My question is do I have to incorporate the Oracle database into my server in order to use Materials Studio?
Dear You Sing Lim:
As you might be aware, Amazon EC2 uses a flexible deployment model, offering virtual hardware resources for your computing needs. For MS (Materials Studio) applications, the first thing you’ll need to decide is the OS platform choice, Linux or Windows. If you are familiar with HPC computing, then you may want to choose Linux. Otherwise, a Windows workstation VM will be more appropriate.
MS does have component collections (MSC) for PP (Pipeline Pilot). Most applications in MSC doesn’t require a (Oracle) database, unless you are associating some of your MSC screening applications with a database-oriented application.
With Regards,
Jian-jie
Thanks Jian-Jie
I will be using Linux for the OS platform, will explore the application while determine the need of database-oriented application.
