bead radius
Does anyone know if the bead radius in a coarse-grained model may have an influence on the properties calculated by Mesocite?
For example, could a large bead radius prevent water molecules from entering a CNT or the bead radius is used  for  visualization purposes only? It is not clear to me.
Thanks!
Isabel
Answers 3
RA
RA 2013-07-11
Hi Isabel,
The bead radius, as defined on the Bead Type Properties/Defaults dialog, is only used for display in CPK style. It has no effect on the calculation.
The effective size of a bead is controlled by the force field. For instance, in DPD force fields you can change the Rc value of the Soft Harmonic potential to make beads smaller or larger. In principle you could tune the interactions such that one bead blocks access to a nanotube although this may require some trial and error.
Hope this helps.
Reinier
IL
IL 2013-07-15
Hi Reinier!
Thanks once again!
JD
JD 2013-07-17
The bead radius does affect the bond length when you build a new mesomolecule. But the bond length is ultimately controlled by the forcefield you choose.
