Bead connector in mesostructure
Hello everyone,
I have a mesostructure in which I wish to delete all bead connectors connected to bead A. I tried running the following script -
#!perl
use strict;
use Getopt::Long;
use MaterialsScript qw(:all);
my \\\$doc=\\\$Documents{"Mesostructure.xsd"};
my \\\$beads=\\\$doc->UnitCell->Sets("S")->Beads;
my \\\$connectors = \\\$doc->UnitCell->BeadConnectors;
foreach my \\\$connector (@\\\$connectors) {
my \\\$bead1 =\\\$doc->UnitCell->Beads("X");
my \\\$bead2 =\\\$doc->UnitCell->Beads("A");
\\\$connector->\\\$bead1;
\\\$connector->\\\$bead2;
\\\$connector->Delete;
But I get the error - 'The index value is invalid (function/property "Beads") at -e line 11.' Can someone tell if there is a way to do this?
Thanks,
Ricky
Answers 1
RA
RA 2023-04-11 Best Answer
Did you mean to delete all connectors for bead-type 'A'? In that case you could use
foreach my $connector (@$connectors) {
    my $type1 = $connector->Bead1->BeadTypeName;
    my $type2 = $connector->Bead2->BeadTypeName;
    $connector->Delete if ($type1 eq 'A' || $type2 eq 'A');
In your code, $doc->UnitCell->Beads("A") returns the first bead with name 'A'. If there is no bead with that name you get an error like that.
