Hello All
I want to write a script that performs same analysis on the multiple trajectory files stored in one Folder say Folder1. Say my project structure is:
Project:
-- Folder1
-- Folder2
-- Folder3
First I intended to do this through \\\$Documents collection but that gives me a list of all the files in project including other sub folders even (or especially) if i run the srcipt from Folder1. I tried to write simple perl script:
#!perl
use strict;
use Getopt::Long;
use MaterialsScript qw(:all);
my \\\$i = 1;
my \\\$dirname = "\\Folder1";
opendir (DIR,\\\$dirname) || die "Can't open folder";
while (my \\\$filename = readdir(DIR)){
my \\\$doc = Documents->Import(\\\$dirname.\\\$filename);
print "\\\$filename\\n";
closedir(DIR)
The print is just to check if it works. It does not and i got the "Can't open folder at -e line 10." error. For the record i used / and \\ it does not help. Do you know the solution?
Lukasz
