I have done the TS Searching job, and found the transition state, I started TS Confirmation job, then met this error: “Error in parameters file: problems parsing file for keyword TSSEARCH_METHOD”. Not sure what is the reason?
the error message is:
License checkout of MS_castep successful
Abort(1) on node 0 (rank 0 in comm 0): application called MPI_Abort(MPI_COMM_WORLD, 1) - process 0
node045
node045
node045
the .para file is:
task : TransitionStateSearch
comment : CASTEP calculation from BIOVIA Materials Studio 2023
xc_functional : PBE
spin_polarized : false
spin_orbit_coupling : false
opt_strategy : Default
page_wvfns : 0
cut_off_energy : 489.800000000000011
grid_scale : 1.500000000000000
fine_grid_scale : 1.500000000000000
finite_basis_corr : 0
elec_energy_tol : 2.000000000000000e-06
max_scf_cycles : 100
fix_occupancy : false
metals_method : dm
mixing_scheme : Pulay
mix_charge_amp : 0.500000000000000
mix_charge_gmax : 1.500000000000000
mix_history_length : 20
nextra_bands : 125
smearing_width : 0.100000000000000
num_dump_cycles : 0
tssearch_method : conNEB
tssearch_force_tol : 0.100000000000000
tssearch_disp_tol : 0.005000000000000
tssearch_energy_tol : 2.000000000000000e-05
tssearch_max_path_points : 10
geom_force_tol : 0.100000000000000
calculate_ELF : false
calculate_stress : false
popn_calculate : true
calculate_hirshfeld : true
calculate_densdiff : true
popn_bond_cutoff : 3.000000000000000
pdos_calculate_weights : false
Appreciate any help to solve this.
There are some glitches with the documentation of the tssearch_method keyword in Materials Studio 2023. I have to do some further reading.
The conNEB keyword works for me though.
Which Windows version is this exactly (What does winver say (https://support.microsoft.com/en-us/windows/which-version-of-windows-operating-system-am-i-running-628bec99-476a-2c13-5296-9dd081cdd808 )?
Is this a 32bit or 64bit Windows version?
On which platform exactly are you trying to to the CASTEP run itself?
Are you sure that you run the CASTEP version which comes with Materials Studio 2023?
