adding water molecules to solvate a given system on a metal surface in MS
when using Materials Studio (MS), how can someone add water molecules (say 200 water molecules) just above a molecule that is docked on a metal surface. May you also suggest how to keep the atoms of the metal surface (and those of the water molecules) fixed when doing an optimisation.
Answers 1
JD
JD 2012-07-09
Hi enoebenso,
Have you tried the Packing task in Amorphous Cell? You can use it to add the water to the existing (periodic) structure with docked molecule. Check out the "Packing molecules into existing structures" tutorial. You can fix atoms in place by selecting them and then Modify | Constraints | Fix Cartesian Position.
Best,
/Jason
