About Cordinates file
Dear all,
Do anybody know how can i change Cordinates in the input file?
As far as i think, I should go to .car file and can put my new cordinates system there. And run the simulation again. Cam i do this?
Answers 3
BM
BM 2014-08-06
Hi
Can you give a context to this? Which module are you trying to run? Typically you should not need to modify server input files directly unless you are running servers in standalone mode i.e. outside of Materials Studio. For example if you want to run  Discover via the Materials Studio interface with a modified .car/.mdf file, then you modify the structure in the visualizer and then submit your Discover job. The structure will be saved as a .car/.mdf file pair and used in the job.
Regards
Simon
SG
SG 2014-08-16
Dear Simon,
I am using Dmol3 outside material studio. I was thinking that instead of making a new input file and all, i want to change just the cordinate file and rerun the simulations again. I this way i dont need to do file transfer and all.
So my idea is the following way:-
1) If my simulation is not succesfull, i will use the material studio visualizer to create the same file again.
2) Instead of transfering all the files, i want to copy the cordiantes of the system.
3) and paste the cordinates to the same file which was unsuccessful before and re run it.
I dont know if i can do that for the same system with everything same (atoms). Just curious if i can do that.
BM
BM 2014-08-16
Hi
Thta sounds reasonable. It would work for Discover and though I am no DMOL expert I I think that it should work for DMOl. Try it!
Regards
S.
