Hi every one,
Using the Amorpous cell module I built a cell with 100 molecules of water (14,4x14,4x14,4), with Compass forcefield, Qeq charge equilibration, Ewald electrostatic and Atom based VdW, then with forcite I've done a geometry optimization.
In order to estimate the viscosity of water (just for test purpose) I used the Forcite shear job, and COMPASS as a forcefield, for the dynamic parameter I used a time step of 1fs with the NVT ensemble and with T=298K, obviously, the shear direction does not affect the results because my system is isentropic, so I used the software default value (B (BC)), However, the shear rate should be chosen carefully to get accurate results, of course the average is calculated after equilibration of the system, so here is a table with some of my results:
Shear rate (1/ps) | Average viscosity (cp) | Std. Dev. viscosity (cp) |
0,3 | 0.242 | 0.809 |
0,4 | 0.272 | 0.587 |
0,5 | 0.257 | 0.445 |
0,6 | 0.221 | 0.371 |
As you can see, the viscosity is too low compared to experimental results (0.896 cP at 298K).
In the other hand, I tried to change the target temperature, but strangely, there is no considerable change in the values!
And I don't know how to explain this...
Thank you very much
JARRAY
Hi Jarray,
I recommend using COMPASS charges and a larger system. I have gotten 0.50cP for the viscosity of water with COMPASS. I used 2100 atoms (700 molecules) and a shear rate of 0.1/ps. I ran two shear jobs, one to equilibrate and then a restart for production. Each was 100ps long. I used the NHL thermostat and group based charge cutoffs.
Best,
/Jason
Hi Jarray,
Viscosity of water is notoriously difficult to predict; in [1] a comparison of some water models (wiki) was made (using stress autocorrelation)
Clearly there is quite a spread, and all are too low compared to experiment. The COMPASS water model is a 3-site model like TIP3P and SPC/E, but flexible. Because of the sensitivity I would not recommend QEq charging, since it depends on the configuration in which the calculation was made; it might be better to use fixed charges on all hydrogen and oxygen atoms (as Jason noted already).
We did some tests on argon (87 K , 1 atm; Universal) comparing the shear method with stress autocorrelation analysis and experiment.
Reinier
[1] M.A. González and J.L.F. Abascal, The shear viscosity of rigid water models, J. Chem. Phys. 132, 096101 (2010) (link)
Thank you very much,
This was very useful, i'll try them out.
JARRAY
